Its the BDP-S300 and one of the choices are Y,Pb,and some other thing cant remember. The other choices I think are R-0255 and some other code dont know what the name is unfortunately. I think its RGB- and some number after that. Thanks again
Those two - YPbPr and RGB - indicate different color spaces in video and PCs, respectively.
YPbPr - Wikipedia, the free encyclopedia
The first uses code 16 for black and 235 for white [16-235].
The second uses code 0 for black and 255 for white [0-255].
HD/BD as well as DVD and most other commecial video products are encoded using [16-235],
although JoeSp will tell you otherwise. Hence, to avoid color space conversion, it would be better to go YPbPr.
Remember, that the TV input this player will be connected to should be calibrated for [16-235], i.e. 16 represents black, 235 - white.
If you have multiple devices connected to the same HDMI connector on TV (e.g. HDMI switch with your BD player and a PC that is always using RGB), it is better to let the player do the color conversion (move black to 0) and calibrate the TV for RGB. Between the player, modern AVR and the TV, try to avoid any video manipulation done by the TV: no matter how good, it will be inferior to the same job done by the player/AVR.
Diogen.
