I am looking to update the Satellite file on my SD8000hd. I specifically want all of the transponders updated and the 83w satellite. I am running the 5.14 software but was wondering if there is a separate file to update the satellite list.
support for that unit is down the toilet....its probably best you just add the satellites and transponders yourself manually....its very easy to do....all you need is one active transponder on each satellite to check quality....then just do a blind scan....
I agree with Mikey11, nothing new for this receiver in a long time. Shame really, I like mine. To add 83w I just renamed an adjacent sat, manually entered the TPs from the list and then used the signal quality and motor to locate the TPs. Not an optimal solution, but it works.
