Re-Installed 1.M dish with SG120 motor, Invacom QPH-031 and the microHD, and weird things are happening...The motor at times does not move, motor indicator sign says that is it "moving" but no satellites or channels are found.
Tried to multisatellites scanned from 72W to 116W, the receiver's indicates that it did reach the 116W, but actually it scanned only to 107W in which it was scanned three times in the process.
The motor is inconsistantly moving from satellite to satellite....Punched in channel numbers, "motor moving" indication appears but channels do not show up, "No signal" is very often the case.
Any idea of might be causing this to happen. I am running the coax cable from motor straight to the receiver, new coaxial connection, quality signal if and when, is about 65% to 73%.
