Hi Everyone -- I recently cut the cord from D* and am installing an over-the-air antenna that I'd like to run through the existing D* cabling.
I've searched around the SatelliteGuys forums and many of the posts say I should be able to plug my new over-the-air antenna directly into my former D* cabling and have the antenna work. Unfortunately, it doesn't and there must be some small nuance I'm overlooking.
I recently bought a model OUS00-0681 1byone Outdoor Amplified Antenna (rated for 60 miles; I'm 45 miles away from broadcast towers). This antenna works fine (30 channels) if I connect the antenna using the 20-foot RG-6U cable that came with the antenna directly to the back of a TV, with no splitters or amplifiers in the line.
However, when I connect to the RG-6 cable that was my existing D* cabling (it was installed less than three years ago and worked fine with D* high def service, which I just cancelled), there is zero signal and no channels acquired (with the antenna in the same exact roof position as when it worked on the direct television connection).
I tried the D* cabling both with and without the D* 1 to 4 splitter (model MSPLIT4R1-03) that was left behind. I also directly connected (using a simple RG-6 cable connector) the D* RG-6 line from the dish (about a 50-foot run) to an inside RG-6 cable previously used with my D* service on a TV, bypassing the splitter. Same thing -- no signal at all.
I have also tried this setup with and without the DirecTV Power Inverter (model PI21R1-03) in the line that was left behind, to no avail. I also used the supplied 1byone powered external amplifier where the line connects to the TV using all of these previously described combinations. Nothing works other than a direct connection with the 1byone RG-6C cable from the antenna only to a single TV.
The existing three-year-old D* cabling has this printed on it: Perfect Vision 80SC RG-6 18AWG 75oC CATV/CL2 E232510(UL) CM.
Does anyone have any suggestions how I can get this to work on my existing DirecTV cabling? I will eventually be using the antenna signal split three ways to three TVs, with cable runs (after the splitter) of approximately 10, 20, and 40 feet. I am planning to plug the 1byone powered external amplifier into the incoming line from the antenna then into the input for the signal splitter.
This is maddening, eh?!
Thanks!
Thanks!
