Solid 6 foot dish
Timeclock
64
26
tenn
Will a solid 6' dish receive decent C-Band FTA in tennessee - Do not care about HD - At one time I had a chart which compared dish size to signal strength in the US,( anyone have something like it? ) Thanks
If you are only allowed to install a 6 foot dish, it is capable of receiving most MPEG2 transponders. If you could install an 8-10 foot dish, then most MPEG2 and MPEG4 channels would be received. It makes no sense to go with a 6 foot unless you have no other option.
The challenge with using an undersized dish is that the wider beam width does not attenuate the signals from the adjacent satellite. You may pick-up enough signal with a small reflector to provide a reliable signal lock, but often the next-door satellite signals wash out the tuned satellite signal. The satellite footprint charts are only predictions of the estimated signal strength of a transponders fully loaded with channels and running at full power. They do not take into consideration that most transponders are not run at full saturation or for what signals are going to interfere from the adjacent satellite.
Reactions: Pixl and norman881
C1WPLL Question ???
Unkown H2H
