Nope.. both bad ideas.. just hit it lightly with a broom. If you need to be creative cold water and soap.i was without DirecTV for a day, because Erie got a big snow storm, would a cover help, or putting Silicone on the dish?
thanks
you could also purchase a dish heater to prevent from ever happening again.i was without DirecTV for a day, because Erie got a big snow storm, would a cover help, or putting Silicone on the dish?
thanks
yesterday , my brother was over and unfortunately my dish is to high for him to reach, unlike his dish where at his apartment where he can reach his bedroom room and clean it off, what about super soaker? can we that with hot waterNope.. both bad ideas.. just hit it lightly with a broom. If you need to be creative cold water and soap.
Hot water will freeze faster outside in cold weather. Use cool wateryesterday , my brother was over and unfortunately my dish is to high for him to reach, unlike his dish where at his apartment where he can reach his bedroom room and clean it off, what about super soaker? can we that with hot water
so super soaker are ok? they won't ruin the dish or the cables?Hot water will freeze faster outside in cold weather. Use cool water
Nope that's fine. As long as your above freezing the garden hose will suffice as well. For the amount of time it will take to clear the dish off. Soap will help prevent the water from freezing on the reflectorso super soaker are ok? they won't ruin the dish or the cables?
No...i was without DirecTV for a day, because Erie got a big snow storm, would a cover help, or putting Silicone on the dish?
thanks
world direcTV install a heater?, and where it plug in?Dish heater is your best option IF your in an area that gets the WET snow often.
They can be expensive ...
Generally speaking just snow on the dish won't cause it, but Wet snow will.
That is due to Dish's low look angle and very likely poor alignment.My dish (VT) was covered in snow the other night with zero interruptions. My buddy who has had Directv for years has never once had to clear snow off his dish to get signal... In Vermont. My parents (also in VT) lose their signal with flurries with Dish Network.
No directv will not install this for you.
As twizt3dkitty said, No D* will not do the install.
One thing I recommend for those that live in snow areas is to see if the dish can be mounted on a pole, this way you can always walk out and dust it/scrape it off if needed.
Fwiw, I have also had a lot of snow build up on the dish and still have signal fine ... when the wet snow comes is when I have to keep an eye on it.
