Hi all,
I just tried searching and did not find a clear answer to this. I have a ViP622 and just activated the slingguide. After playing around with slingguide for a bit, it seems to me that we should no longer need the IR repeater when using a slingbox with the 622/722. I noticed that slingguide allows you to add your slingbox to your account. Does this mean the IR repeater isn't necessary? So, using slingguide, when you're watching remotely over the slingbox, are channel changes sent to the DVR via ethernet? Also, it would make the most sense to allow selection of TV1 or TV2 when changing the channel via slingbox (because it is installation dependent). Has Dish taken advantage of this or do we still need to use an IR repeater to use a slingbox with the 622/722?
I would test this but don't have a slingbox. However, I would buy one if the IR repeater isn't needed and the TV2 output could be used exclusively for the slingbox (currently difficult because TV2 is UHF controllable only).
TIA.
TIA.
