Directv installed a Slim Line dish a few months ago. I came home to the dish almost on the ground from all the rain. How much concrete should I need to fix this?
Northern. I think I have a 60lb bag somewhere in the garage. Thanks!
Get the pole straight & true, then have DirecTV do the final adjustments on the dish.Northern. I think I have a 60lb bag somewhere in the garage. Thanks!
They should, but of course we do not know the whole story from the OP as to why the installer did not. It is not that hard to get the metal pole straight & Plumb. As for getting the dish at the right Azimuth & angles, it can be a little harder, depending on their setup.I think he's gonna try to do it himself .... which is perfectly fine.
Otherwise, he should call D* and get them back out and do the pole as well as the point, seeing they obviously didn't do it correct the first time.
Don't all you installers use concrete on all your pole mounts ?
If the pole was 3' in the ground, it should not have moved, unless they only placed the pole 1 to 1 1/2 feet in the ground, with a large diameter hole. If the installer had used a Post Hole digger, and only went say 18" in the ground, and tamped the earth in as they went, the whole assembly should not moved. Sounds that it is possibly that the whole was too large to begin with as I stated before, and pole not far enough down in the ground.
Jimbo,
It is a case of ignorance that can be fixed.........but stupid is forever.
No amount of concrete will fix some installations. The pole has to continue into firm earth and be dented or deformed within the concrete to prevent spin when the winds blows. The pole must be plumb when the whole think is finished.
From what has been described I would say the pole was not driven into firm soil and the dish was put on the pole before the concrete had hardened. This produced a crack that rain began to flow through producing the fail of the rig.
A fix = break up the concrete and add one bag of quick set without water. While holding the pole plumb pound the concrete / dry mix with a maul until it holds the pole up. With a wood block to protect the pole end...drive it into firm soil. Tune the dish and pound the concrete some more. Ground water will set the rig up in a day....maybe some sticks for temp support couldn't hurt. If this happens again look at how water flows in the area of the rig...maybe move it.....get it done before the ground freezes.
Joe
If the pole was just driven into undisturbed soil, it would last for quite a while, until you get someone standing there pushing back and forth on it. You just have to have a long enough piece of steel tubing to drive into the ground far enough.If they didn't use concrete, I wouldn't expect it to last anyways.
If you have a Arc or Mig Welder, you can also weld the bolts on, vs. drilling into the pole to attach.Good call ...
I always drill a hole in the pole and put a bolt thru the end before placing to prevent the spinning of the pole.
Where they put it has a lot of sand. The end of the pole is pinched and I put two bolts through it in two directions before I poured the concrete. I put the dish on a brick roof mount temporarily. How long should I wait before I put the dish back on the pole? I poured the concrete today.
A whole lot quicker, then trying to drill through the pole.Why would you go to the trouble of welding the bolt ?
