Hi all, just wanted to share a simple mast hinge idea I came up with years ago that makes working on and installing a small outdoor antenna much safer. Instead of climbing a ladder up onto the roof and reaching up high next to the edge of the roof (not safe) go to one of the big box stores and buy a large triangle hinge, some U-bolts, grounding rod and clamp. Attached are pictures showing how it is installed. This allows the mast to be lowered onto a saw horse or other support and the antenna installed from ground level.
The mast came from a fence supply company (available in 20 foot sections and different diameters).
The grounding clamp gets installed above the hinge and the thick ground wire gets pulled out when lowering the mast.
Only requirement is you will need an area that is clear in the direction the mast gets lowered.
Hope the pictures gives ideas on a better way to install an antenna.
