I've looked here on the forums for answers to these questions, but I can't seem to find them, so here goes:
I'm trying to slave an Uniden Supra analog IRD to my Fortec Star Lifetime Ultra DVB receiver, and having no luck. I put a DC block on the signal out connector on the Fortec between the two receivers. I understand that I set the satellite and polarity with the Fortec (current transponder), but still no love. Answers to these questions may help me:
1. Does anyone know of a hot analog KU feed I can try to lock onto?
2. When I plug in the video and audio out cables from the Uniden, do I need to make sure they are going into a television set on which I have the channel correctly set (to channel 3 or 4)? [I only have video-in connections left on my set, and they have no tuner, so setting them to 3 or 4 is impossible.]
3. Do I set the Fortec on 'standby', 'on', or completely off to have the signal pass through to the Uniden?
4. Am I correct in guessing that the skew set on the Uniden has no effect, having already been taken care of by the Fortec?
5. Are there very few analog KU transponders active out there anymore?
6. Does having the correct satellite name set in the Uniden have any effect (I'm guessing no.)? Shouldn't I simply be able to find a satellite with a similar frequency layout and call that satellite, and then fine tune the frequency? [Obviously, the satellites have changed almost completely from when this receiver was made.]
7. Is there anything else I'm missing? (Obviously, I'm missing something....)
Thanks for any help you can provide.
