I did self install using Direct TV Slimline 3 with SL3S LNB and all was fine until I had to move my receivers and cabling around. I am now 99% convinced that my LNBis fried since I can get no signal and the power inverter has blinking light. Even though the Lnb worked when I got it I noticed it had something loose inside that made clinking sound when I shook it.
Direct TV support person suggests the light will blink if I don't have satellite signal but this makes no sense to me and seems to certainly more indicative of a short or other hardware issue. Can someone confirm that I should have solid green light regardless of signal stength when everything is connected?
I tried putting on an old LNB I had kicking around (18LNBR0-02)) and the pwer inserter light went solid, which seems to confirm my notion that the SL3S LNB is fried?
- HR24/100
- Slimline 3 Dish
- SL3S LNB
- SWM 4 way splitter (I have a standard receiver as well)
- Power Inserter
**Should note that I get 771A error from the receiver**
- HR24/100
- Slimline 3 Dish
- SL3S LNB
- Power Inserter
