skystar 2 2.23 question..
docj2005
294
st louis park mn
i just got a skystar 2.23 card and in mytheater it only see's the verical transponders.. what am i doing wrong.. or is there some setting for
i am slaviing the sky star off my vision plus card so i still have motor control..
If you're slaving it off of another device, it will only see the transponders on the polarity the primary device is set to. You'll have to change channels on the VisionPlus to something that's horizontally polarized to get the SkyStar to see horizontal channels.
(The polarization is set by the voltage levels sent to the LNB, either 13V or 18V. If you have device B slaved to device A, device A is the one sending power to the LNB, and is blocking the power that device B is sending. It may be better for you to get an LNB with two outputs, so that each device can control polarization independently.)
Use Saar's enhanced drivers or Mibi's SS2disqc1.9 drivers and you will have motor control.
Saar's drivers are in Mytheatre/drivers/techinsat folder.
Mibi's drivers you can find at dvbskystar dot com in the download area.
NOTE. with these drivers you must use the "have disc" option when installing. don't allow window to pick the best driver, because it won't work. I call it forcing the driver install, you pick update driver and keep clicking until you see "have disc", select, then browse to the drivers you want to try.
Init error means you have not gotten Mibi's drivers to load.
Did you choose update driver in device manager, and then click until you find "Have Disc"?
The only way is to force the driver install, windows will alway choose the wrong driver.
SS2diseqc1.9 troubleshooting
Does the plugin show under "Plugins"?
Did you enter your lat anf long? (Negative number for North America)
Did you configure the plugin? (Select motor, etc)
Any error messages?
What version card?,
what version of techinsat software?,
Did you install all of Techinsat's software?,
What is between thn the card and LNB, switches, motor, etc?
What type of LNB?
Any tone switches?
What happen when you go into Mytheatre's positioner consule?
This set up will not work. The twinhan card will strip (mute) the diseqc command being sent by the SS2 card. You can not even have a signal meter in line. The SS2 card has a very good diseqc command, but it does not seem to have a lot of amplitude (volume).
Loop Out Question
Coolsat can't find some satellites
