Skew problem
cazelly
19
Hi,
I have problem with C-band channels... Every time I move my dish to certain satellite ..I have to skew some channels even thoug that I've already adjusted it previously. For example I move to a sat A ..I adjust my skeww to better reception, then I move to sat B , I do the samething. Then I move back to Sat A , and I found that my skewing has change , and I have to adjust it again. Can anyone please tell me what could it be?...Thank you
What kind of equipment are you using, that would help us figure out the possibilities.
If you're using a big dish and an older analog receiver, and older lnb with polarotor, sounds like the receiver isn't storing your skew adjustments properly. Most of the later ones would store the individual adjustments you make by each satellite, if the memory is working properly.
Channell reception trouble
Thanks Turbosat. I have a Pansat DVB 2500 A receiver, 10' dish, Chaparral Corotor dual C/Ku Band LNB, Trak SIX analog receiver which its only use is to move the dish..
The skewing is done by Pansat receiver.
what size dish for satmex 5 @116
Cal Amp mini mag
