SHVERA/Significantly Viewed
colofan said:
So does this mean that if I get a waiver from the stations listed in my county then other out of market stations can not challenge my waiver?
This is an e-mail that I received from DirecTv corporate offices:
Please note the information below with regard to your questions on the significantly viewed legislation under SHVERA.
There are many changes to DIRECTV systems and processes that will be made because of SHVERA. We are still evaluating the full impact and will be tackling issues as quickly as possible given available resources.
Under the new legislation DIRECTV has the right but not the obligation to provide significantly viewed stations to customers in markets where we currently provide local channels. There are a number of factors that will go into determining where we can and will provide these additional channels. We are currently working out the technical process that will allow us to deliver such stations. Once that has been finalized, DIRECTV must determine which stations we can technically provide and which would be of the most benefit to our subscribers. Then we must notify local stations of our intent to provide a significantly viewed station to customers in their market at least 60-days before launching service. Given all these issues we do not expect a rapid deployment of these channels and no schedule is currently available.
Things you should know about Significantly Viewed:
1. This provision of the law does not impact which stations are in
your home DMA and will not require DIRECTV to remove any station you are currently receiving.
2. If DIRECTV is able to provide significantly viewed stations in
your area they will be added to your existing channel list.
3. In most areas not all stations from neighboring markets are
designated as significantly viewed and the list of significantly viewed stations varies by county.
4. In some areas it will not be technically possible for DIRECTV
to provide the significantly viewed stations because of satellite coverage limitations.
I hope this clarifies the issues for you.
Sincerely,
Catherine Slocum-Nall
Senior Manager
Programming Acquisitions
DIRECTV
2230 East Imperial Highway
El Segundo, CA 90245
Tele: 310.964.4969
Fax: 310.535.5416
cslocum-nall@directv.com
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
-----Original Message-----
Sent: Wednesday, February 09, 2005 9:59 AM
To: 'gfs_fla@bellsouth.net'
Cc: Slocum-Nall, Catherine
Subject: RE: SHIVA
I am forwarding your message to my colleague, Catherine Slocum-Nall, who
manages our local channel distribution.
Thanks,
Reagan
