Many of you guys seem very knowledgable about antenna systems, so I'll present my situation and see if you have any answers.
I now have a Antenna Craft D9000 VHF-UHF-FM antenna on a rotor and I can get all of the stations in our area with no problem with it. However, I recently got a ViP-622 DVR, so having an antenna on a rotor is not a good way to go.
If you go to antennaweb.org and put in my zip code 94114 you'll see that I have lots of digital stations to chose from. Sutro Tower with 11 UHF stations is just 3/4 of a mile west of me, Mt. San Bruno with 3 stations (1 VHF on 12 and 2 UHFs) is 5 miles to the south, two UHF's are 30 miles to the east and four UHF's are 35 miles to the southeast. You'll also see a lot of stations in Sacramento 60 - 65 miles away, but you can forget those. There are high hills between and there and we can't get any of those stations.
Now can any of you figure out a way to connect four different antennas into one down feed so that I can eliminate the rotor and have all of the signals available for recording? The stations from Sutro Tower come in on just about anything, since I'm so close, but the others actually need a real antenna pointed at them.
I have two 4228's and a 4221 in the basement that are available for this project. I can use the 4221 for the Sutro stations, a 4228 for the stations 5 and 30 miles out, and the D9000 for the ones at 35 miles, but I can't figure out a way to connect all of the antennas together.
Since there is more than one station in each direction, I don't think a Jointenna will work, except for possibly in the southeast direction. The stations there transmit on channels 49, 50, 51 and 52, so maybe a Jointenna for 50 or 51 would work... maybe not.
Anyway, if any of you have any ideas, I'd certainly appreciate hearing them.
By the way, as others have pointed out, the 4228 UHF antenna works fine for VHF channel 12.
Larry
SF
Larry
SF
