Hi,
We live in an apartment that supplies one main satellite. Our service is DirectTV. Last December I bought a DirectTV DVR and hooked it up. After a little chit chat back and forth with DirectTV the DVR worked.
Our Setup:
We have the cable from the wall going to a splitter, out of the splitter to both the SAT 1 and SAT 2 so we can record two shows at one time.
It worked ok for about a few days and then I notice that it kept losing the signal. Then the picture would get scrambled slightly with sound issues then the signal would be lost off and on again. Mostly I saw this with the lower channels but it really affected all the channels in the end.
I would reset the DVR unplug it and plug it back in. Sometimes that worked for about a day or less.
This last time I plugged it back in after I had the issue again and the DVR would not find the signal at all.
After removing the Splitter and only plugging into SAT 1 it worked great and has had no problems at all. But of course we can only recored one program and not watch anything while it is recording.
I have tried moving the DVR to other TV's to see if the issue is just with the cable in the main room, but with the same outcome.
Is the signal too weak to use a splitter?
Thanks for any help in getting this to work right.
Nick
Our Setup:
Nick
