Signal Quality - Newbie Question
I apologize if this is a repeat post. I did a search and spent about 2 hours trying to find the answer, but was unsuccessful.
I have a 522 and a 510. The signal quality in the setup screen on my 510 is 110 - 115. The quality on my 522 is 95-100. The RG6 run from the dish to the 510 is shorter than the run to the 522.
1. Is this the reason for the loss of signal quality to the 522 the length of the cable?
2. Or, is the DPP switch that used to split a single output into two for the 522 the reason?
3. Would I get a better signal quality if I re-run the feed to the 522 and use a shorter route?
4. Does any of this matter since I have signal quality between 95-100 on one receiver and above 100 on another?
Thanks for your help.
