I set up my new system: Captiveworks 600 , Fortec Star 90 dish, stab 90 rotor, invacom quad lnb......I used a satellite finder meter to locate my southmost satellite....located AMC 3......zip is 60440 so its my southmost satellite. The satellite has good signal off of the tester....dialed the tester all the way down and tweaked the dish.....looking good.....but my captiveworks shows zero for quality and 75 for signal.....what did I do wrong...or could i have a hardware issue....i tried bypassing the motor, no difference...then i tried bypassing the diseqc switch .....came right off of the lnb which is an invacom quad.....still same results....all cable is brand new rg6.......any suggestions.....? This is my first FTA setup.....just getting into the hobby....so I am a newbie and probably missed something.....
I also tried changing the settings in the setup section. Tried USALS and Disqc setups and also made sure my lnb was selected manually....still no change at all on the quality bar of my captiveworks system. Test meter shows good signal off of the dish so not sure where to go now....the vendor gosatellite.net wasnt sure what the problem was......talked with them for over 2 hours troubleshooting.....they recommended contacting a local installer and suggested that I have a dish pointing issue.....which would seem right given the zero for quality.....but I really think i have the dish pointed properly and took the time to plum everything properly.....can my portable satellite meter be incorrect?
