Signal Problem when sunny and hot
Frank Sharper
maryland
My system loses signal when it is sunny and hot outside. Could you supply any answers to this problem. When it gets dark and cools off outside I get a good picture.
Without more information, my first guess is you have an LNB going bad. Do you, by chance, have a SuperDish?
indeed i think you answered your question within your question. the lnb needs replacing
LNB or switch
I could be either the LNB or the switch heating up. A minor third possibility of cable problem splice that has moisture in it that when it heats up causes a problem.
To the OP... do you have OTA connected? Hot, humid, & clear weather can create a situation in the atmosphere called "ducting" and OTA signals will become... well lack for a better term... weird. Check the pip sorce & make sure that it's on a sat signal & not an OTA channel... this should help...
It's a software bug that's been around a while, if the pip is tuned to a weak OTA the unit will give a LOS box when the OTA is out, even if watching Sat or DVR...
Mississippi announces $125k Settlement with Dish Network
Dishnetwork activation without SSN (not prepaid)
