Hi, folks.
Well, I've been working on the dish farm a little bit. I have a 90cm on the roof, and it's for 87 & 91. To date, I only had the 87 tuned in, since I didn't get the time to dedicate to the dual LNB. I'm using a Geosatpro 4 degree kit, and the matching bullet LNBs with two outputs.
On the roof, I have a lock on the signals, and it is as close to the sweet spot as I can get.
LPB comes in at 7.7dB
CNN comes in at 6.0dB
I'm using one of the ebay ~$40 Satlink WS-6933 meters, and Q is around 29% - 33% (fluctuates a bit) on each of these TPs.
However, something changes by the time it gets down to the basement where my switch is.
After the run through ~40 feet of coax, CNN has dropped to 4.7dB. My X2 receiver can't lock it in, and gives the Q at 20%.
LPB in the basement still locks in fine at 6.0dB.
These are numbers straight off the coax, and not running through my Pansat 8x1 switch.
This suggests to me that there is a loss in the coax, and I know that over long runs, loss can be significant. But I wouldn't expect it to be that big over just 40 feet or so.
Coax is Tappan dual shield RG-6. It tests fine (no shorts) on my coax tracker.
I have a couple of thoughts:
1) Not enough signal here for sharing 87 & 91 on a single dish with these LNBs?
2) Interference in the wall run with multiple cables?
3) Would quad-shield coax help this situation? I would rather not pull new coax, but I can do it if it is going to improve things.
I appreciate any suggestions!
This is my meter here: Satlink WS-6933 DVB-S DVB-S2 FTA C&KU Band Digital Satellite Signal Finder Meter 690002124813 | eBay
This is my coax tracker here: 8 Way Coax Cable Locator Mapper Toner Tracer Finder Identifier Tool RG6 Vericom | eBay
