HI,
I cannot seem to figure out what is causing a problem I am having with the system.
traxis 3500, winegard, 2100 motor with adapter.
Before you get all worried about the setup, everything has been working flawlessly for a long while now.
I haven't watched the satellite for a few weeks and when I turned on the receiver it was locked (wouldn't turn on from remote or buttons on the receiver). I ended up unplugging and replugging it in and it became responsive.
SO here is the bulk of the problem.
I wasn't getting much of anything so figured maybe dish was a bit off from wind or earthquake or something.
SO I went to the menu and used the motor to turn left or right (e/w) a bit and mostly no matter what sat I point to I get only 1-2 transponders weakly instead of the 3-4-5-6+ that I was getting.
Watching the signal quality, I got the ladder out and put a gentle little push on the dish - up - down, left, right, twist and signal does not improve. Usually it WOULD improve if the dish was misaligned a bit.
But here is the weird part. For many transponders that have a weak signal, watching the meter while doing NOTHING, the quality will jump all over the place (0-19 or 28-40) back and forth.
Now occassionally I have a really strong signal on a transponder and I get great reception. Later nothing. I had all the PBS in, now I do not.
NOTHING on the system has changed. Cables are fine, don't see how dish would warp suddenly, especially when sometimes I get perfect reception on some transponders.
I do not know if it is the LNB, dish, receiver?
Anyone have experience with this??
Please help, I am losing my mind...
Thank you all in advance!
Kevin
Southern Cal
traxis 3500
winegard, 2100 motor w/ adapter
Kevin
Southern Cal
traxis 3500
