Are you 100% certain your look angles are correct?
If so, are you using existing cables in the home?
Sometimes, if it is pre-wired for cable, there can be splitters inside the walls and/or attic that are NOT compatible with satellite. Not to mention not being RG6.
Run a good RG6 cable directly from the dish to your receiver for setup. See if that works.
