I have about a 5 year old system, round dish, dual LNB (?? 2 cables off it), RCA receiver, and dish mounted over the air antenna. One cable from LNB to antenna, one cable from antenna to splitter at the receiver (100' cable), two short cables to back of receiver. Signal strength mid 90's. Installed it myself, followed directions, and not a ounce of problems until recently. In Savannah, Georgia.
The last couple of years I noticed the signal strength going down. Still good picture, I did not worry about it.
Last couple of weeks signal strength in the 50's. Most everything I read pointed to alignment. Screwed around with alignment a couple of days, nothing better than 50, I never checked anything but 101W and transponder 1.
Finally cut some higher tree limbs out the way.
Now I have signal strength in the low to mid 90's on the odd transponders and no signal on the even ones. I am not sure I ever had anything on the even ones. In addition I am missing a quarter of the channels 206, 207, 230, 360 are a few.
Any suggestions?
It install so easy and has been very reliable, I have not learned much about it.
Great forum, graet advice, but most on new equipment.
Thanks,
Will
Any suggestions?
Thanks,
Will
