Iceberg said:not possible because of the same frequencies
Iceberg said:That is possible, but I think the OP wants to control 2 dishes with 2 different boxes
What you're describing is basically slaving a box
oh...he needs 2 high freq, voltage pass, A-B switches, just joking!!gopher2 said:I have 2 dishes and 2 recievers and i want them to use 1 coax
I want a box i can put at both ends to share the cable at the same time
jerryt said:You can have one cable from each reciever, going to a single 4x4 multiswitch. but both lnb's have to be duals and niether lnb can be a Universal.
Then both reciever can access both lnb's without interferring with the other reciever.
Up to four reciever can be wired to this one 4x4 multiswitch.
Very simple
Very simple
Iceberg said:OP isn't trying to do that. He is trying to combine 2 dishes onto one cable, bring it into the house and then split it out to 2 receivers.
W_Tracy_Parnell said:So if I wanted to run my 3500 and the Coolsat (or the 3500 and a PC card) the only way would be a dual LNB and 2 lines?
