alton987 said:After the update my DVI connection cuts out every 3 seconds. All other conections work just fine its just the DVI output that is beening affected in all Res Modes. Any Ideas????
Sean Mota said:That's strange. I also have DVI and everything looked fine this morning and last night. Just as a check (you probably did this), check your connections and resolution on the STB has to match the resolution of your display.
Also, try to unplug/plug the STB to see if that brings back to normal. Please report back.
GeneWildershair said:ok blackouts are back, and it does get rid of the info guide, when I have it up... yet if I put it on the signals page, it doesn't black out at all for some reason? Also the black out actually blacks for a split second, then it switches to a fuzzy screen, and sound is gone. Then it returns to full picture and sound.
Shleprock said:I'm having the same problem as reported here:
http://www.satelliteguys.us/showthread.php?t=10487
Losing signal on a regular cycle. Also should be noted that if I hit the red button to cycle output it will no longer give me a picture on 480p or 480i - nothing but snow.
I no longer have to unplug ther receiver every two hours, it is shutting itself down on a regular basis !
owlbox said:HDCP compatibility problems maybe???
