I have a Shaw Away-From Home receiver, which is an older model that I use at my Summer and Winter cottages.
My problem is that my dishes - both model 60E - have different LNB's - one is a LM-2738-SC, and the other is an MSOC-1631LAN. I have used both LNB's OK, but every time I change, I have to call Shaw for a factory reset of the receiver to match the other LNB.
I have three questions -
1. Why is this necessary when the input frequencies, output frequencies and polarization specifications are identical for both LNB's?
2. Is there any way I can do the factory reset without getting Shaw assistance? They are very helpful, but it is a time-consuming procedure I would rather avoid.
3. If the only answer is to use two identical LNB's, which is the best choice, and where can I get one?
Thanks,
Wintexan
Thanks,
Wintexan
