Hello folks,
I'm in the process of getting Shaw Direct setup at my house. I had a satellite installer come out and do the install and using a meter he said he had signal strength in the 90s for 107 and 111. I have the 75E dish with quad output LNB.
I'm at the point of getting the two receivers I have setup and neither of them can get any signal strength. I tried running the coax directly from the LNB into the receivers and both of them stay stuck at zero signal strength.
On the installation setup I have tried plugging in 4128 for the Provider ID and it still just stays red with zero signal strength.
I'm starting to think that the LNB is toast because I have read that I should still get some kind of signal reading even if the dish is pointed at the wrong place? There doesn't seem to be much else I can try other than picking up a new LNB and swapping it out? Is it possible that the installer could tell the signal strength to the satellites if the LNB was toast though?
I'm used to the Bell setup where the LNB runs to a powered multi-switch. With this Shaw gear I'm just running coax right from the LNB to the receiver. Is that right? (no power required). Just trying to make sure I didn't miss something obvious... =)
Please let me know if you have any ideas/suggestions. Would be greatly appreciated!
Thanks!!
Thanks!!
