Have had this motor for a few years, has worked well until about 2 weeks ago... completely quit working, no movement using any of my DISEqC capable receivers. Green light under the motor indicates power and the LNBF functions fine. Tried to re-set the motor using the small hole with mini switch inside and felt a bit of a crunch as I pushed in my non-metallic tuner tool. No change.
Removed the motor and took to bench for dis-assembly. Found corrosion around the (reset) switch area of the circuit board. Found a replacment switch off an old circuit board, cleaned the area, soldered in the new switch and re-assembled the motor.
Installed and seems to work except... now the motor seems to (forget) where it is pointing every time I turn off the receiver! It always thinks it is at true south when I boot up the receiver, so if it was on 125w when I shut it down it goes to 153w when I start it up again! If I move it to my true south satellite using diseqc 1.2, turn off LNB power and switch to USALS and turn the LNB power on again it works perfectly fine unitl I shut off the receiver again.
Has any one had this trouble before?
Maybe I messed something up when I soldered in the new switch or it is the wrong switch? I don't have a circuit diagram to know if the switch is special spdt, dpdt, etc...
-C.
-C.
