does any one here know anything about setting up starband? i have a used starband system that I'm pitting up. I'm pointing to the 101 sat with good signal from a cheap ku band meter. but no signal from the starband. i have a hughesnet system and use it on a tripod so I'm good at general aiming. i don't know any setting to see a good signal the cluster and subcluster. does any one here have starband that's pointing to 101? if so can you post your cluster settings? and once i get setup are there any installers that could activate for me? I'm a full time rv'r most wont do it because they know your going to move it around which most people do any way.
		 yes I'm very formilure with that. the 129 is there refereed sat and is were you will go to do the first software upgrade and commissioning. I'm installing my self to save money. then have someone commission for $50. to do this i need to be shire my sat is pointed somewhat correctly by entering a correct combination of cluster numbers (frequency). to get a signal strength through the system. if not they will charge me for a new install. then i might as well go with new and  I'm in the year contract!
