Set up wireless medicom router
MrButts
Gerogia
I need to help with setting up a medicom com wireless router with a netgear wireless router so my hopper will connect to the internet. the guy that installed to new box told me it not possible with a mediacom router
If both routers are going to do actual routing, you've got problems from the start. There are three solutions, either of which should work.
1. Use only the Mediacom wireless router. If it can cover the area you need, there isn't a reason to have another router in the mix. If it won't cover the whole area, you could configure the Netgear to extend the network.
2. Call Mediacom tech support and have their router configuration changed so that it becomes nothing more than a cable modem and use the Netgear for routing. Downside is if you are signed up for their phone service. I think, but don't know for sure, that the phone service requires using their router for all functions.
3. If you don't have their phone service, just get your own cable modem and use your Netgear router. If you do this you'll need to call Mediacom to provision your new cable modem. Make sure you get one that is compatible.
Note that if you choose options 2 or 3 Mediacom tech support won't be of much help if you have a problem with your network in the home.
The reason is that Mediacon Gateways don't generally play nice with the Hoppers via WiFi. The tech should have put a HIC in
Hopper with Sling vs Hopper 3
Hopper 2 Error code 004/005
