I have dish 500--2 lnbfs,plastic [y] with 91 & 82 degrees on it,and 301 rec.1-
s21 switch[dishnetwork]
Each lnbf has 2 coax cable connections on them .Which one of the connecters do i connect to on the lnbfs.
Do i use both lnbf if only have 1 rec.
Should the switch be connected inside\outside house
When locating sat on set up do i remove card or leave in rec.
What is 119,110
On the s21 swith it says to dish 1 to dish 2 [is this reffering to the 2 lnbf on dish.[only have 1 dish ]
olddog
What is 119,110
olddog
