Semi-newb question?
LordKaT
25
9
New York City
I've only ever installed dishes at ground level. I'm considering installing a dish on a deck that's about 12 feet from ground level. Would the maximum object height calculation on dish pointer still be accurate, or could I add those few feet to the height total?
In this case, I've just *barely* got enough clearance to get 123W, but the engineer in me would like more of a comfort zone ;)
From dishpointer, when you click on the red knobby thing:
h
= the maximum height of obstacle measured from the base of the dish.
So it sounds like you'll be able to subtract 12 feet from the height of the object, unless I misunderstand something. ;)
I agree with USDownlink, the maximum height will be referenced to a level plane, actually I think, from the LNB. Of course, unless you have a gigantic dish, your starting to squabble over immeasurable values anyway -- ha.
EDIT: Let me rescind that, I imagine one needs to include the whole reflective surface and would therefore consider the plane at the BASE of the dish, as USDownlink stated....
Bill
More channels or better quality signal
Having problems with setup
