zap2it would work too but its not as easy to add channels.
Titan TV seems to work the best and its customizable depending on which channels you want and what order to put them in. The only drawback I noticed is some channels you can't move to where you want
example...
I have my locals in there at their legit spots (2,4,5,9,11,23,29,41,45) and then I put the FTA channels starting at 100. The exceptions are the networks on G16 as I can put them as what their channel is (ThisTV is 17, ABC is 20, Fox is 24, CW is 30 and NBC 14).....the issue is when you add a channel that might be a subchannel. It logs as what the channel is. So when we found a WSTV affiliate (KFLA 8.2) even if I changed the channel number to say 111 it still showed as 8.2 in the list.
The old analog channels I could put them how I wanted. I used their legit number and had my locals elsewhere
