Welcome to Satelliteguys. It sounds like you only need a small adjustment to your dish. If you can rig a small tv that you can see as you adjust the dish, that is the best way to peak your signal with the least frustration. With a fixed dish that is nearly on target like yours, it is best to gently push on the dish to each side and up/down while watching the signal strength meter (don't loosen the locking bolts yet). This will tell you which direction you need to adjust the dish. Then loosen the locking bolts and then make very small adjustments in the direction you found by pushing on the dish. You might want to make some reference marks so you can return to your initial position if you get off track. You may also try to adjust the lnb distance from the dish and its skew (rotation). This can make a big difference if your aim is as good as it gets. Again, plan to make very small incremental adjustments.
Take some time to browse around the site and take advantage of the search tools. You will be able to benefit from the wealth of info that has been documented by the members here. Good luck.
