satellite signal polarity
central1ny
11
central ny
This may be a stupid question, but I am new to satellite. I was wondering, when I look at the lyngsat website, how can I tell what polarity a Ku beam is on a given satellite? Thank you.
In the far left column labeled "Freq Tp" you will see something like H (for Horizontal), V (for Vertical), L (for Left), R (for Right).
Is this what you were needing? WELCOME to SatGuys!
Thanks for the help. I guess I have a lot to learn. I understand that there is circular and linear polarity when it comes to signals? I did find the following website that states "Digital signals are transmitted from the satellites on either Vertical (V) or Horizontal (H) polarity for linear feeds, or on Right (R) and Left (L) polarity for circular feeds." Starting to make sense.
http://www.satcruiser.com/understanding_polarity.htm
Actually I don't have anything yet. I am trying to learn as much possible so that I purchase the right equipment. My goal is to get a FTA dish, maybe 31". The primary use is for one-way satellite internet on AMC6 sat. But I was hoping to be able to get a special bracket and mount a 2nd LNBF to pick up some free channels from other satellites.
Or maybe think about a motor to use/see the entire arc, unless you just have to use a fixed setup and I think that bracket will only allow a 2° separation from AMC6's 72.0° location (I might be wrong, as I use a motor). I am also not too familiar with any internet sub from AMC6 other than the Station-53 offering, so not too sure on how that works either; I am not a huge fan because I need quality connection for VoIP use. Maybe think a bit bigger dish size too IMHO.
SA 8300HD Rebooted 3 times last night
Availability
