I haven't did any research to see how satellite radio works, but here is something else to consider.
Direct Broadcase Satellite Service (DBS) generally uses satellites operating in the KU band, from 12.2GHz - 12.7GHz on 32 pre-defined frequencies, i.e., one for each of the 32 transponders.
So Dish Network provides DBS service to the U.S. from several satellites at 61.5, 110, 119, 129, and 148 degrees. Generally, each satellite is using the same frequencies (and polarity). These satellites are using higher power than the other satellite systems, therefore, a smaller dish such as the 18" dish can be used.
But this dish antenna is also serving as a direction antenna, without it, you would be attempting to pick up signals from all 5 satellites at the same time, and this is not including the satellites from the other service provider (DirecTV). It would be like being half-way between 2 regular TV stations both operating on Channel 5.
