Satellite finder install
RLDSL
49
4
Can I leave a satellite finder permanantly installed in the coax inside the house to help locate new satellites, or would this cause too much signal degradation?
Thanks-----------Robert
can I ask why would you weant to keep it in line?
If you have a motor, its not needed :)
heck, I have a fixed dish and I dont need a meter :D
I used to keep one in line all the time back when it was all analog, but you would be just as easy using the receivers quality signal meter, but it can be done, the test is go to a very weak signal with the meter in line then check your quality on screen, then check again with it removed, I used to enjoy seeing the signal rise and fall as I swept the arc.
The signal quality meter doesn't display itself when just moving around, it only shows when on the fine tune screen of the menue, but you can't make any large adjustments with the motor from there, so thats why I was wondering about keeping the meter hooked up so I can find everything.
----------Robert
Very true, if there is no signal loss maybe a good idea, I know my old satellite guru friend (Telstar/Larry, RIP) always had a analog meter in line.
Explain this?
Mount St Helens ready to blow!
