Satellite C3 Channels
txag67
I have a Motorola 922 receiver and recently noticed that channels 100 through 127 are not available. I get the "can't find channel, continuing to search" message. Everything else appears normal on C3 and other satellites.
Any suggestions?????
Sounds like maybe the dish might be off a little. Have you tried to bump it east or west to see if it will get a lock. Mine does that occasionally, the actuater won't stop where it's supposed to and I'll get a reading like that. I'll bump it and it comes in. You may also need to get a rehit, which seems more likely. Sometimes for one reason or another, the 4dtv seems to lose some/all channels, and it takes a rehit to get them back. NPS has an On-Line hit for there subscribers. Maybe your provider does too. If not give them a call, a rehit doesn't cost anything. If they're not busy, it won't take long.
Al
Thanks, I'll try that tonight. I did the power-off reboot last night with no success.
100-127 are all vertical - are you able to get other vertical channels on C3? If not, check your skew settings to be sure they're not the same for H and V on that satellite.
Oddly enough, the problem disappeared yesterday. Channels 125-127 are still not available, but they have always been hit or miss; similar to 112-117 on G1.
7.5 foot Wingard free to good home
Time Change Question
