satellite 119 replaced with 43690
koconnor
12
I had everything align correctly when I decided to fine tune the system. I started using the xponder on the different satellites to get the best signal. 119 was coming in the strongest at 100 with the other in the upper 80's. Before I knew what was going on I lost 119 and it was replaced with satellite 43690. Any ideas what happened and how to fix?
Thank you for the reply. I'm still having the problem. I will try replacing the LNB unit unless you have other ideas.
New Channels
If I have ordered NFL ST....
