Sat Setup
Apprentice
345
Wichita Kansas
Ok attached is the way I think it should go but it don't work. I am sure I am missing something simple and just not getting it. Can someone line me out on what should be done instead of what I am doing :confused:
Chuck
  • Satellite Setup Document.pdf
Get rid of the ota. Run that seperate. The only time I would run a diplexer is in a simple switch free setup. One dish and an ota antenna. With more than one dish, in my opinion you are better off seperating the ota from the sat signal. I don't think that ota signals and diseqc switches get along all that well.
I thought about doing that. Just running another cable to each room for the OTA. Might be easier. but would be nice to do it in one run.
Put a 2 way splitter after your OTA antenna then diplex outside the house between your 4X2 switch and each receiver, connecting one diplexer for each receiver run. Then diplex at the receivers.
Bob
I will try that and see how that works. I have plenty of dipexers so no problem to try that. Rat Shack carries perfect vision ones here for like 9 dollars so I bought a few :)
Thanks wescopc
Working Now
Thanks for the help with the setup. The attached is what was suggested and works just fine :)
Chuck
  • Two dish and two STB setup.pdf
Did I just get a 4200v doorstop??
