Same Signal Strength across the board
sgt940
26
4
Used to be an advid user on here but haven't had a need lately. I do have a question I have started having pixelization issues on multiple channels including prime channels. Checked my signal strength on 110, 119, 129 across all satellites across all channels across all tuners waiting a couple of minutes between changes ALL signal strengths are exactly 62 never changes. Maybe 61 when you change channels or satellite but goes to 62. I know this is an acceptable level but isn't it strange everything is 62?
You are making sure to change the satellite/transponder in the point dish screen, correct? If you have a multi tuner receiver, it might be that one tuner is sticking to the same sat/trans even when you change channels, so instead of changing channels and checking the signal afterwards it might be better to leave one single channel on in the background and just change the sat/trans values manually. Some to check would be 110/119 transponder 15 and 16 for both, and for 129 transponder 17 is my go to. 119 transponder 21 is the hottest in my area (Houston) at 82-83 using a Hopper3/1000.2
Reactions: TheKrell
Echostar 23 to co-locate with Nimiq 5
Info about Hopper Duo
