Saint Louis (STL) - KDTL-LD & KBGU-LP
sparkie951
Saint Louis, Mo
I am having problems in receiving 2 stations (KDTL-LD & KBGU-LP). GPS shows me at 16.6 miles from the tower from Antenna to Antenna and they are located on the Same tower as KPLR
They appear to be Collocated on the same tower (based on GPS Coordinates. ( 38° 34′ 24″ N, 90° 19′ 30″ W or 38.573333, -90.325 ). (My locations is 38.728746 -90.562654 )
KDTL-LD is using RF Channel 16 at 15 KW which should not be a problem and KBGU-LP is using RF Channel 27 at 15 KW which I see as a real potential problem.
The Real potential problem is Station KPLR who owns the station is on RF channel 26 (Neighboring) at 1,000 KW on top of the tower.
My Antenna setup as follows (Top to Bottom)
2 - Channel Master CM-4228 8 Bay Panel Antennas (Pointed about 30 degree angle from each other
1 - CM-0500 (Jointenna for Cophasing)
1 - CM-3201 LTE Filter
1 - CM-4778 (Medium Gain) Pole Amp
1 - SM-3414 (4 Channel) Distribution Amp
Any advise would be appreciated.
Localish to replace Live Well Network
Trying to figure out best antenna 64 miles
