Sailboat Dish Installation
bigec2002
15
Does anyone have any tips for installing a small dish i.e dish or directv on a sailboat?? Of course it wouldnt be for when out at sea but when in docked in port at a slip, or maybe when anchored depending on sea conditions. I've heard of mounts on a servo motor which is controlled on signal strength but sounds pricey. Also, when in port will minimal wave variations affect the incoming signal to a degree where it will disrrupt the incoming picture?? Any help would be greatly appreciated. Thanks.
Most people that I've seen with dishes for their boats have mounted the dish on post attached to the dock.
Going to be hard to keep it on signal. DTV does make a device that goes on the top of a car or van that will stay locked when driving down the road but it is pricey.
I think so.... Even with a normal dish mount, you can "push" on the dish itself enough to decrease the signal, so yes,
even slight movements will be a problem.
Verizon takes on cable companies as it seeks TV market
Using Satellite in Central America
