Blowout Inventory Reduction Sale
120CM Fortec Star Ku Offset Free To Air Satellite Dish Antenna
Price $199.99 (FREE SHIPPING 48 States)
Specs. & pictures:
http://www.sadoun.com/Sat/Products/F...sh-antenna.htm
REFLECTOR
Type Offset
Offset Angle 24.62 0
Short Axis 120 cm (47")
[FONT=Verdana, Arial]Long[/FONT][FONT=Verdana, Arial] Axis[/FONT] 132 cm (52")
Aperture Efficiency 75% min.
C – Band Gain @ 4.0 GHz 32.78 dB
KU – Band Gain @12.5 GHz 43.32 dB
F/D Ratio 0.6
Focus Length 720 mm (28.3")
Material Galvanized Steel
Finish Polyester Powder Coating
Color OFF WHITE
MOUNTING
Mounting Type Ground, Pole & Wall Mount
Adjustment Type AZ / EL Mount
Elevation Angle Range 25° - 77°; 17° - 90°
Azimuth 0° - 360°
Material Steel
LNBF Arm Length 755mm (29 3/4")
LNBF Arm Support Struts Length 901mm (35 1/2")
Color OFF WHITE
Pole Diameter Acceptable 45 – 75 mm (1.75" - 3")
Net Weight 31[FONT=Verdana, Arial] lbs reflector and brackets without floor mount [/FONT]
ENVIRONMENT
Operational Winds 25 m / sec
Survival Winds 50 m / sec
Ambient Temperature -40°C ~ +60°C
Relative Humidity 0 ~ 100 %
This offer is for a limited time (expiring 5/31/09) or while supplies last.
Sorry no rain-checks.
Ok forum fans, now you have no excuse not to start your Mini - BUD project where you can get KU and C-Band (most satellites) on one small dish.
Mini BUD project:
To complete your Mini BUD project you will need to get the following additional components that work well with the above dish:
- Dish comes with a Universal type Roof, Wall mount with side support struts
- 40mm LNBF holder included.
- White color available only.
- Dish has a rectangular style tubing to hold LNBF.
- DSS LNBFs will mount directly to the LNBF arm without the need to use the LNBF holder.
- Works great for commercial satellite reception as well
- Floor mount and LNBF are optional.
Specs. & pictures:
REFLECTOR
Type Offset
F/D Ratio 0.6
Color OFF WHITE
MOUNTING
Azimuth 0° - 360°
Material Steel
Color OFF WHITE
ENVIRONMENT
Mini BUD project:
