My Sadoun 1.8M polar mount dish arrived around 4:30PM from UPS. There was no visible damage, but asked the driver to stay while I opened and checked the contents. The dish was well packaged with the 5 sided box inside another regular 4 sided box. A quick cutting the box open revealed no internal damage either. Would have been hard to imagine how any damage could occur with it double boxed, but maybe something could have been bent from the factory.
It arrived in 3 packages and I had assumed the big 5 sided one was the dish panels, a second would be the polar mount, and the third would be my GeoSat dual output C Band LNB. But I was wrong, the LNB was packed inside the biggest box with the dish panels. The other two were the polar ring mount and an unexpected 76mm diameter pedestal with three 21mm diameter fixed length braces and 6 anchor bolts.
I had already decided I would use one of my old Hughesnet J mounts for this dish and already had it mounted and plumbed. So the pedestal will be surplus. It is designed to mount on a concrete pad with the 6 anchor bolts. My J mount braces are adjustable in length, so plumbing it is a rather easy task even on my low slope garage roof. I would suggest the braces for the pedestal would be better if they also were adjustable. BTW there was one set of 6 anchor bolts with the pedestal and another set of 6 anchor bolts packed with the dish. None of these are listed on the parts diagram.
My first step was to modify a piece of PVC pipe I planned to use to help fill the gap between my 2 3/8” OD J mount and the 3” ID of the azimuth mount. Marked the bolt locations and length on the PVC. Then drilled oversized holes, so the azimuth mount bolts would not push against the PVC; but directly on the J mount steel. Finally cut the PVC to length. Inserted it into the azimuth mount and threaded the bolts through the holes which then would hold the PVC insert in place.
Second, sort out the hardware. This yielded a M6x50 mystery bolt not listed on the diagram. Also three other larger nuts & washers with no known function. They are the same size as the ones used to attach the ring mount to the polar mount.
Third, attach the polar mount to the azimuth mount. Note: to do this - first attach the elevation adjustment bolt to its bracket, before putting the hinge bolt in place.
Fourth, attach the angle iron to the ring mount. This was the worst part of the assembly. The factory welds the bolt in place on the angle iron bracket, but failed to mask the threads of the bolt. When the bracket is spray painted the bolt threads are filled with enough paint to make threading a nut on nearly impossible. Thought I’d just run a die over it and clean the threads, but my tap & die set isn’t metric. So had to take an Exacto knife and chip paint out until I could at least start the nut. Then used the nut to clean the excess paint from the threads.
Fifth, attach the triangular mount for the actuator arm onto the polar mount. Note the diagram shows this on the opposite side from what I determined would work best for me. But that varies with installation location across the country.
Sixth, attach the ring to the ring mount and angle iron bracket. Not sure which orientation is best for the bolts. I opted to have the bolt head towards the panels, but may discover later this isn’t the best direction. Note the dish support ring is different for the polar mount than for the fixed mount version that Sadoun sells. The fixed mount has three mounting brackets welded on. The polar version has no brackets, only six holes to allow attaching the ring mount and angle iron either left or right.
Seventh, by this time the 6Mx50 mystery bolt function became apparent. It holds the dish center cover in place. BTW, neither the center cover nor its bracket are listed on the parts diagram. Also not sure which side of the cover is front or back. Suspect it may become apparent with assembly of the dish.
Note the Sadoun 1.8M design differs from the Fortec design in how the declination adjustment is accomplished. This uses just one bolt, the other uses two. Looks like using only one would be easier to adjust. Also the ring mount bracket is long enough that a magnetic inclinometer can fit on the bracket to check the declination angle, without have to use a board or something to span the face of the dish. And the elevation can likewise be measured easily on the polar mount bracket.
The dish does not come with elevation and declination angle information. I took this data from Sadoun’s DG240 motor owner’s manual.
The cold front and its high winds are expected to blow out in a day or so. When it does, I’ll assemble the dish panels, attach the polar mount assembly and put it on my J mount.
Then install the actuator arm and find some satellites. I’ll have more pictures and text at that time.
