Openbox s9 open box help.
satmex
7
Santa Clarita Ca
I have a new s9 open box that I never got to set up and the problem is that the satellite list I don't see
97w (G19) or 125w (G14) the list only shows telestar 12 (orion2) 15 west the others are east I can't see this satellites from my location, I'm at lat 34.4476 long -118.667 how can I change this list? any up dates that I can use to change list. thanks in advance.
satmex.
You can rename them, and change their location *Safest solution* OR:
First - make a backup of your TP_Prog.dbs then on your computer rename it ORIG_TP_Prog.dbs
Then copy this American List TP_Prog.dbs (Unzip it first) to the stick and upload it to the receiver.
Think it's the list I used, otherwise, why did I save it ???? *Unsure if it's compatible with all FW versions.
  • TP_PROG.zip
you can edit the list with the remote using the various colored buttons.
From the amount of programming left it wouldn't take long.
I do that with euro firmware I play with,I just edit in 72w.
AMIKO Amiko HD SE- Channel Information
GEOSATpro Flashing Video - C and ku
