Not sure if this is the right forum for this, but I am having a weird issue in one room in my house. In this room, I have both my FireStick and a Roku Premier+ (the original) connected to my TV. They also both connect to a 2.4GHz Wi-Fi network which doesn't interfere with neighboring channels and has a relatively low noise floor (-100 dBm) and good SNR (-40:-100). I have the same problem with both devices. After a certain amount of time (at least 30 minutes), both will stop reacting to remote control inputs.
The solution to both is the same: Pull the batteries on the remote, and then the streaming devices start responding again. I know the Roku will use the same wireless channel that the device is using to stream, but I am not sure how the FireStick works, or if it uses wifi for remote connectivity at all. It doesn't seem to matter what streaming app I am using when this happens. Netflix, Hulu, Prime Video, and Dish Anywhere(not Roku obviously) have all exhibited the problem.
Streaming devices on wifi in other rooms do not exhibit the issue
I am open to suggestions on how to troubleshoot the problem.
Thanks,
Ted
Thanks,
Ted
