Two questions regarding the cable going into the receiver (not of course the receiver's RF output cable):
1) Do I need to buy RG6 with an attached ground wire? I assume so but just want to make sure since I'm not fully informed yet as to what is needed to fully and properly ground the system.
2) What is the maximum cable run permitted for use with my setup (standard Ku LNB and SG2100)? My assumption here is that you need to add up all lengths between the LNB and receiver if you have a motor/switch(es)/ground block in the middle?
Thanks for your help
