RG6 cable underground in PVC conduit
I got everything hooked up and it actually works. :) One more question. I put 2 ground clamps on my copper grounding rod. One for the antenna, and one for the coaxial cable. Is that OK ?
Thanks.
Yes, that is probably fine (mostly).
The point is to have only *one* grounding point for all equipment involved. If you have have ground at the antenna, and then another 100 feet awat at the house, you can have a difference in ground potential that can zap reception, if not destroy your electronics.
So if you ground with a single rod, and that sits close to the reciever, you should be fine.
Do note that you need to ground your electric installation as well (and you need to be a qualified electrician), or else you may create a potential difference to zap your electronics there too.
Start TV has been added on KASA-DT
WWNY Watertown NY
