I need to buy about 160 feet of RG6 for my OTA antenna run outside. Been to a few places the the prices locally (Home Depot, Lowes, ACE) and the price differences are pretty amazing.
I realize there are different quality cables..but the prices vary by as much a $.30 or more per foot in some instances. Some of the real cheap stuff $.19 a foot has nothing marked info on the cable casing....Others say 18AWG which I know is .040 inch and is a pretty decent thickness. Some a quad shielded others and double shielded. Some are marked "Super Satellite RG6 18AWG" others are marked Series 6 Continental Cable Company. A few say tested to 2200MHz, other say nothing.
I thought RG6 is RG6..that is has to meet a certain standard to be considered RG6 and has to function at a certain level to be used where RG6 applications are called for.
Is there any easy method a simple old infantry soldier like me can use when I go to buy cable..
Something like "Make sure it's 18 AWG, and center wire is 100% copper, and it's at least double shielded". I assume that the local cable companies and satellite installers use a good quality cable...not some copper coated steel wire.
Home Depot has a 500 foot roll of 18AWG RG6 coax for $45, ACE hardware has their Super Satellite RG6 18AWG wire at $.31 a foot..so for 160 feet will cost $49.60.
What should I be looking for when I buy RG6?
I had bought 100 ft of Phillips RG6 18AWG 100% copper quad shielded coax a while back..but need to add an additional 50-60 feet more to that run. I was going to get an extra length of the same coax and uses a barrel connector with di-electric grease and tape to splice the two lengths together. I was told to just buy a solid length of coax rather than splice.
How much signal will I use with a good splice?
